PROBLEM WITH I64 LabVIEW 8.6
Strange behavior in LabVIEW 8.6.
The result of my subtraction (I64) with a matrix is false.
If I visualize the matrix subtraction before it becomes good.
(see jpg or vi)
Can anyone help me?
Thank you.
CAIOLA Didier
(4,074 Views)
Bug- Deffinately
  • Opened in 2009- correct function
  • opened in 8.6.1- bug observed
  • saved for 8.5.1- bug observed
  • saved for 8.20- Bug observed
  • Replaced all functions- bug observed
  • Swapped subtrahend and sutractor - bug observed
Bug related to the subtrahend in quad 2d instance of subtract I64 & U64 does not follow to I/U32
Message Edited by Jeff Bohrer on 01-26-2010 10:47 AM
(4,048 Views)
Very interesting.
I can confirm I see the behavior in LV 8.6.  And I don't see it in LV2009f2.  I do see the behavior in LV 8.2.1 and 8.5.1.
I would suspect something to do with buffer allocations.  But when I looked at the buffer allocations in LV2009 and LV8.6, the dots showed up in all the same places.
(4,046 Views)
seen in 8.0 as well-
(7.1 and earlier do not support quad ints )
Subtract is not in the list of changed or modified vi's in the 2009 help
Message Edited by Jeff Bohrer on 01-26-2010 10:55 AM
(4,043 Views)
Look at this link and search for 134607
https://www.ni.com/en/support/documentation/bugs/09/archived--labview-2009-bug-fixes.html
The description of that bug fixed in LV2009 seems very similar to this situation.
Also look here. https://www.ni.com/en/support/documentation/bugs/08/archived--labview-8-6-x-known-issues.html#134607...
Maybe fixing that bug essentially fixed the bug you are seeing.
(4,039 Views)
Good eye Ravens
(4,035 Views)
