07-29-2005 08:06 AM - edited 07-29-2005 08:06 AM
Message Edited by Support on 09-15-2005 10:45 AM
07-29-2005 11:03 AM
07-29-2005 11:12 AM
07-30-2005 10:57 PM
07-31-2005 02:49 AM
07-31-2005 03:21 AM
07-31-2005 03:48 AM
Well, I'm not sure what your problem is exactly.
Since the VI was opening and closing fast, I added a wait function in it. When I did this, the Value property nodes you used started to generate errors that the VI is not in a state compatible with the operation. To be honest, I have no idea why this error occured, but I resolved it by wiring the value from the control instead of using the Value property (which is not a good way, anyway).
07-31-2005 10:12 AM
Hi, tst
first of all many thanks for your help.
now the problem is , when i put a chekmark on the first test on the main i get the reslut in the get_t1[subvi],its work ok.
the result shold be:
test name: power up cur.
min value=0.18;
max value=1000;
total mean=3.530;
standart deviation=51,7066;
pass mean=0.87;
standart deviation[pass]=5.07;
know if i'm gonig back to main program and take the tx freq1 test or a different test i get the result of the first test.
the result of tx freq is:
min valu=888.799;
max value=901.816;
total mean=901.779;
standart deviation=0.68;
pass mean=901.815;
standart deviation[pass]=0.000363;
i try to modifay the bulid table function in the get_t1.vi but i get more trable with that. i think that the problem is there.
what do think?...
regards
eyal.
07-31-2005 12:46 PM
I really don't know. Your code is very hard to follow. What I suggest is that you clean it up a lot (make subVIs, follow the style guide) and document it, and you may find out what the problem is on your own. Even if you don't, it will be much easier for someone else to.
07-31-2005 02:23 PM
