PROBLEMS TO BUILD WITH LABVIEW 7.1
HI EVERYONE... MY ENGLISH ISN'T VERY WELLL BUT I TRUST IT.
I NEED BUILD MY PROJECT... I HAVE TOO MANY VI's AND ONE CALL OTHERS VI's... I HAVE A FOLDER (C:\SIMULADOR CEV\INTEGRACION) AND INSIDE HAVE 5 FOLDERS MORE WHERE ARE DISTRIBUTED THE VI's.
I HAVE 3 VI's THAT ARE GLOBAL VARIABLES... AND INTERCHANGE INFORMATION BEETWEN VI's.
MY PROBLEM IS THAT I BUILD THE PRINCIPAL VI (AND I SUPOUSE THAT LABVIEW BUILD ALL VI's AUTOMATIC) BUT WHEN I EXECUTE IT... TWO VI's DON'T EXECUTE.
I HOPE THAT YOU CAN HELP ME... THANKS AND SORRY FOR MY ENGLISH 😉
HOLA A TODOS... MI INGLES NO ES MUY BUENO PERO LO INTENTARÉ...
NECESITO COMPILAR MI PROYECTO... TENGO MUCHOS VI's Y UNO DE ELLOS MANDA LLAMAR LOS DEMAS VI's... TENGO UNA CARPETA (C:\SIMULADOR CEV\INTEGRACION) Y DENTRO DE ELLA TENGO OTRAS 5 CARPETAS MAS DONDE ESTAN DISTRIBUIDOS LOS VI's.
TENGO 3 ARCHIVOS DE VARIABLES GLOBALES... DE DONDE OBTIENEN INFORMACION LA MAYORIA DE LOS VI's.
MI PROBLEMA ES QUE COMPILO EL PRINCIPAL Y SUPONGO QUE COMPILA AUTOMATICAMENTE LOS DEMAS... PERO A LA HORA DE EJECUTARLO 2 VI's NO SE EJECUTAN.
ESPERO QUE PUEDAN AYUDARME... GRACIAS Y DISCULPEN MI INGLES
(2,351 Views)
We need some more details - What do you mean by "don't execute"? Do you get a message saying that they can't be found? Do they produce an error? Are these VIs you wrote or VIs which came from someone else? Are you calling these VIs dynamically? Does your program work in the development environment?
___________________
Try to take over the world!
(2,336 Views)
