PROGRAMMING
Can someone tell me what kind of structure is this in the picture (the blue square) and were I can find it in Labview 2010? It is not a function, not a loop..., what is it?
Thanks very much.
LV
Message 1 of 11
(5,058 Views)
Looks like a script node, for matlab or 'c' perhaps?
Kudos are (always) welcome for the good post. 🙂
Message 2 of 11
(5,053 Views)
Hello jmoya
This is MathSctipt node. You can find it under Programming->Structures (or pressing ctrl+space and typing MathScript in quick drop window).
Message 3 of 11
(5,048 Views)
That would be the MathScript Node
Message 4 of 11
(5,047 Views)
Take note that the Mathscript node is an extra cost add-on.
Message 5 of 11
(5,042 Views)
Dear odessy27, PiDi, crossrulz, Dennis_Knutson. All of you are rigth!
Unfortunately I have not got this add-on, that why I didn´t find it. Thank you very much!
I have to find another solution.
Message 6 of 11
(5,029 Views)
You can use Formula Node, which is in base package.
Message 7 of 11
(5,019 Views)
That code looks simple enough to just do in LabVIEW.  For loop with a shift register and Replace Array Subset.
Message 8 of 11
(5,016 Views)
The problem is that I don't understand that code, for example, what does it means F(1+P+a*i)=1. F is an array, but F(1+P+a*i)=1?
I have to find someone to explain to me that code in MathCad, and then transform to your proposals in Labview.
Anyway, thank you very much, now I know where to go on with my programming.
Message 9 of 11
(4,997 Views)
Everything inside of the parentheses evaluates to an index of the F array.
Message 10 of 11
(4,979 Views)
