PROPERTY NODE PROBLEM
hello friends,
i have a big Problem. i want to open Excel on labviews, so i create 4 subIVs.
in one subIV i want to connect AUTOMATION MODE with a PROPERTY NODE called _Application.
If i do this, the property VISIBLE changes his colour from green to black and then i cant connect VISBILE to the boolean.
what can i do, sorry for my bad english.
Message 1 of 8
(4,911 Views)
Hi yzqamar,
are you trying to do something like this?
Message 2 of 8
(4,905 Views)
Message 3 of 8
(4,904 Views)
Yes Sir. exactly this is it, but when i connect Automation Mode to Property Node "Visible" gets black
Message 4 of 8
(4,902 Views)
That's because you need an Automation Refnum control that you assigned the Excel Application class to, not an Automation Container. The container only can instantiate Active X control capable classes and the Excel.Application is not an Active X control class but an ActiveX automation class.
The Excel ActiveX container class does not have a Visible property, Instead you make the container itself visible or invisible through a LabVIEW property for that object.
Rolf Kalbermatter  My Blog
Message 5 of 8
(4,874 Views)
But GerdW also send the Code which is similar to my Code.
and How i do a refnum? sorry but its my first day on LabVIEW..
Message 6 of 8
(4,850 Views)
Accepted by topic author yzqamar
After that right click on it and select Select ActiveX Class->Browse...
Message 7 of 8
(4,844 Views)
i thank you very much, you just safed my life
Message 8 of 8
(4,839 Views)
