PSD with dB ON: is it 10*log(x) or log(x) ?
The Power Spectral Density (PSD) in LabView has an option of outputing dB values. I have found that it do this: 10*log(x). I just want to confirm that this is the case in all versions of LabView (I have 8.6) because If I am to use that program in different system I do not want different outputs that may be confusing.
(3,789 Views)
I see no indication in the detailed help that it has since changed in more recent versions of LabVIEW, but I can't personally verify that it will behave exactly the same across mutliple versions.
Matt W.
(3,751 Views)
Is it 10 Log or 20 Log?
(3,663 Views)
10 for power, 20 for volts, I believe.  This is related to Ohm's Law for power equations.
Bill
CLD
(Mid-Level minion.)
(3,637 Views)
PSD assumes 50 Ohms default when converting Vrms^2 to dBm (deciBels relative to the milliWatt).  in all versions of LabVIEW 8.6 to date.  I doubt that will ever change
E=I*R
P=I*E
can't really be changed too muchSmiley Wink
(3,631 Views)
