PUTTING A CALIBRATION LINE IN A WAVEFORM CHART
Hi, I want to calibrate my min and max, and so i need two lines in a
waveform chart (i use to do this in a waveform Graph with cursors, but it
just doesn't work well when your doing data acquisition) Does anyone knows
how to do this on a waveform chart?!
Thijs
(2,583 Views)
I had similar problem some years ago developing EMC testing software. The measured spectrum shouldn't cross some reference curve (not even horizontal but with ramps). I just constructed the curve and added it to the waveform graph (as if it were an extra input-channel, take the same length as the measured curve). It worked and it's simple.
(2,583 Views)
