PWM Actuator control and monitoring
I am working on a personnal project and I need to control three (or maybe 4) linear actuators (fyi, dyadic SCN6 (uncertain as of now if i'll be using SCN6-020/040 or 060, but they are pretty much the same). (Spec Sheet: http://www.miraiintertech.com/home/downloads/Dyadic1003.pdf )
I do have some LabView skills, but i do lack some electronic skills to determine how to have LabView control those actuators.
I have a LabView Vi that i want to use to send some (help me here) PWM signals to control the actuators... I might need to monitor them as well to have a better control.
So my question as of now is, what do i need to do that, what kind of PWM controller/card (I don't have a clue), and can you provide me some knowledge regarding this technology.
Thank you very much,
Marc
Message Edited by Chronik on 05-03-2010 10:17 PM
(4,191 Views)
There are a lot of possible choices of hardware you can use to generate a PWM signal. Take a look at this Developer Zone artcle about using PWM and DAQmx. Do you have any hardware already or a form factor in mind? What sort of monitoring did you have in mind? That’s a very open question and I’d hate to go off on a tangent.
Matt
(4,144 Views)
Thanks for the reply,
After looking around, I might have to do it differently than i first expected.
I will use LabView to send position orders to the SCN6 actuators. From what i heard, I think i'll have to use some LabView compatible card with (analog) outputs, that then will then connect to somekind of servo-motor that then will be able to drive the actuators' motor according to my LabView's instructions...
PS: I said analog, because the guy i talked to said it might be better for me to send analog signals than doing PWM and sending the bit to change the direction
I really need help here, as you can see !
(4,140 Views)
OK, if you run into more trouble, post back with some more information and we can try and figure out what’s happening.
Matt
(4,117 Views)
