PWM Measuring with ANALOG INPUT (NI-9205).
Hi
Is it possible to use ANALOG INPUT (NI-9205) for PWM frequency measurements?
Yonatan
Message 1 of 10
(2,694 Views)
The short answer is yes, however, you will have to take some things into account:
  • How fast is the PWM signal.
  • Do you need more than one channel (is the a QUAD encoder)
  • Can you write the code to do the PWM processing
Are you using the NI-9205 because you have it or are you thinking of buying it? If you have it and you are trying to use what you have then it can be done to a point. If you have not purchased this card there are better ways to do PWM measurement.
Tim
GHSP
Message 2 of 10
(2,659 Views)
Hi TIM
Thanks for your replay.
  • How fast is the PWM signal  =>  0-1kHz
  • Do you need more than one channel => I'm using more channels but not for PWM measurements (for Voltage input).
  • Can you write the code to do the PWM processing => This is a simulation and I want to produce the PWM from the software the truth is that I encountered some difficulties and I am not sure what to use... I am using Analog output NI-9623 (I also have NI-9269) and than I tried Square waveform.vi, Square wave.vi, Square wavePtbyPt.vi. With Square wave.vi I can see the wave in the INDICATOR that displays  x-y graph but then it cannot be connected to the AO from some reason.
Actually, I have also NI-9221, NI-9203, NI-9361, NI-9223, and NI 9215.
I do not really know who is best to use.
I would be happy for a recommendation on this subject.
Yonatan
Message 3 of 10
(2,634 Views)
Hi
I was able to obtain the module NI- 9403, DIO.
I want to produce the PWM from the software. I tried Square waveform.vi, Square wave.vi, Square wavePtbyPt.vi. I can see the waves in the INDICATOR that displays x-y graph but how can it be "wired" to the AO module?.
I also tried from programming => Waveform=> Digital Wfm to coonect the AO but with no succees.
The input of the module is true or false...
Yonatan
Message 4 of 10
(2,585 Views)
Hi yonatan,
you forgot to attach your VI and so we cannot tell you, what you did wrong in your code...
Message 5 of 10
(2,581 Views)
Hi
I am using cRIO 9035.
I have the NI- 9403, DIO module.
I need to produce PWM wave. I tried to use Square waveform.vi, Square wave.vi, Square wavePtbyPt.vi. which I have found in the examples. I can see the waves in the INDICATORs that displays x-y graph but how can it be "wired" to the AO module?.
I also tried from programming => Waveform=> Digital Wfm to connect the AO but with no success.
The input of the module accepting only True or False...
Yonatan
Message 6 of 10
(2,593 Views)
well the 9403 is a DIGITAL IO module! program PWM in the fpga if you can.
Message 7 of 10
(2,575 Views)
Hi rivlin,
instead of creating double posts/threads you should answer the questions given to you...
Message 8 of 10
(2,571 Views)
Hi
Message 9 of 10
(2,523 Views)
Hi
What is the best way to generate and read PWM signal?
I have DI and DO modules
I am using the cRIO 9035 and the frequency is 0-1000Hz.
Yonatan
Message 10 of 10
(2,505 Views)
