PWM control through USB 6008/09
Hi Lynn
Ok. If I have understood this right, is this what you are talkin about?
I have attached a file. please check it.
Regards
Nikhil
Many more Kudos to give 🙂
Many more Kudos to give:)
Message 11 of 35
(3,191 Views)
t06afre
I actually will need an amplification of 2.4.
will tat circuit give me such an amplification?
and a current varying from 140mA to 300mA or so.
Regards
Nikhil
Message 12 of 35
(3,210 Views)
somebody reply please :smileysad:
Message 13 of 35
(3,200 Views)
t06afre
Let me give more info.
As you all know, the USB 6008 has an output analog pin of 0-5V. The pump runs @12VDC and current varies the pressure.
The current specs (according to the data sheet ) varies from 320mA to 350mA.
Practical connections across the Variable voltage source indicates current varying from 140mA to 300mA.
Please refer the data sheet for more info.
http://www.hargravesfluidics.com/pdf/BTC-IIS/ST_D771-11_C.1F28G1.1F28N1.B12VDC_Rev_A.pdf
Message 14 of 35
(3,171 Views)
Hi my timezone is GMT+1 so I has been in dreamland for some time now
Well some quick answers
>C7 and C3 are variable capacitance
Nope they are standard polarized capasitors. The best thing to use is tantalum capacitors. They should be rated to 25V
> And also, what must be the gain of Q1?
A opamp may deliver max 20mA . Let us say we want to draw max 10 mA, so the Q1 need to have a b or Hfe equal to (max motor currunt/10mA) at least. Q1 boost only current the OPamp is the voltage booster.
Here is some stuff on wiki about OPamps
http://en.wikipedia.org/wiki/Operational_amplifier_applications
Well back to work, the rest must wait
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 15 of 35
(3,159 Views)
Hey, thanks for your reply.
I need 350mA and maintain 12VDC. which means the resistance needs to be very low. can that happen with the darlington emitter?
PS: haha, m sorry about that mate.
Regards
Nikhil
Message 16 of 35
(3,155 Views)
Yes I will say so. Your darlington transistor should be rated for 1 Ampere. I am sure your school has something like it on the lab
Message 17 of 35
(3,151 Views)
Nikhil,
The circuit you posted is the typical arrangement of an LM317 as a voltage regulator.  However, at least 5 mA needs to flow through the resistors at the point you marked as the LM317 connection point.  That is the maximum a the 6008 can produce.  The voltage at that point will be 1.25 volts less than the output voltage.  Since the 6008 can produce a maximum of 5 volts this would not drive the pump to full speed.
The attached circuit uses an op amp to amplify the USB6008 output to 10 V making the motor voltage about 11 volts.  By changing R2 to 120 kΩ or 150 kΩ you would get more gain and higher voltages.  R5 assures that the LM317 output goes to a low value if the USB6008 is not connected.  R3 provides a minimum load to keep the LM317 happy if the motor is not connected.  The diode protects the electronics from energy stored in the inductance of the motor.
Lynn
Message 18 of 35
(3,131 Views)
hey...thanks a lot. lets hope it drives my circuit. shall set it up as soon as I get my "ordered" USB 6008. am still skeptical of the ckt regarding the amount of current supply. none the less, thank you for the interface ckt...cheers mate :smileyhappy:
Message 19 of 35
(3,117 Views)
Hi, committee.
Its is interesting topic that you have discussed, and seems to me there is relevant to my task. I am going to drive a fan motor which is varies with temperature output. The fan motor is rated as 12 volt, 0.32A = 3.84w.  I have checked the output voltage from the software (USB 6008 is very low). Can I use the posted circuit? I believe it is more than enough. Will it not damage the fan motor.
Kind regards
Sufre
Message 20 of 35
(2,496 Views)
