PWM counter pulse
Hello, I am using the counter output of my DAQ 6255 to generate pulse width modulated output. I need to generate pulse trains with varible alternating pulse widths In the attached VI, I am using the DAQ write for writing into counter the variable high times and low times but some how it doesn't work the way I have set up the timing in the array. Can some one help me solve this issue?
(2,595 Views)
Hi MansoorEE,
Hav you looked into the example found in NI Example Finder? Pressuming that you are using the USB 6225, you can open LabVIEW >> Help >> Find Examples... >> Search keyword "pulse width". You can also limit your result as shown on the botton left corner of the screenshot below:
Hope that helps
Warmest regards,
Lennard.C
Learning new things everyday...
(2,536 Views)
