PWM output Labview to Daq
I am using a PCIe-6323 DAQ board and Labview 2014 (32-bit) to generate a pwm signal directly to a voltage output using a square wave. It works fine for a 0, 50, or 100% duty cycle, but any other input just defaults to one of these three. Is there something wrong with the square wave generation or am I missing something else?
(3,518 Views)
Hi Jcook,
how should we answer this from looking at your image?
We don't know whih parameters you use, we don't know how you output your PWM waveform, And there is a coercion dot visible in your image…
Attach a VI with typical values for all controls set as default!
(3,499 Views)
