PWM signal generation by varying duty cycle on USB NI-6366
Good day
I am trying to perform Impedance Spectroscopy (IS) on a Lithium Ion battery while it is supplying power to a load.
I am using a usb NI-6366.
To perform IS I need to inject small sinusoidal signals onto a DC current bias. What I am currently doing is creating a PWM waveform by comparing a triangle waveform (Switching Frequency of 20kHz) to a DC bias with a sine wave. The duty cycle is given by the following equation:
duty cycle = 0.5 + 0.05*sin(2pi*f), where f varies from 0.01Hz - 1kHz.
The PWM signal outputs on an Analog out port of my NI 6366
The issue is, I am unable to produce a decent looking waveform for the low frequencies (0.01Hz) because the number of samples I need to send to the NI-6366 (for the PWM signal) is too large and I am getting buffer overflow issues.
Is there a better way that I can create the PWM waveform, so that I do not have to send so many data points to my NI-6366? Is there a way I can dynamically vary my duty cycle
I also have access to a myRio which has FPGA functionality, if that will be an easier solution.
Any help will be great.
Regards
Sean Moore
(3,356 Views)
Accepted by topic author seanabmoore
Hi Sean,
the example VI "Cont Gen Voltage Wfm-Int Clk-Non Regeneration" explains how to output large amounts of waveform data.
You might split your waveform into smaller parts suitable for your hardware…
(3,321 Views)
Thank you so much. That did the trick.
Regards
Sean Moore
(3,252 Views)
