PWM through NI RIO board
 I have Labview Embedded Platform kit ( NI-RIO) board and want to generate pwm through a joystick, which is connected to my PC.
Through this PWM I have to control a servo motor.
Is this possible with NI evaluation kit that I have? Can I just connect a servo motor with a driver, to any of output port of RIO board?
help needed
(2,461 Views)
Hi NapDynamite,
If your servo has a driver, you can connect the driver to any digital I/O of the kit, you will have 4 I/O available, and you can program the logic that your driver need in the board.
steve.bm
AE | NI
(2,421 Views)
