12-03-2006 10:10 AM
12-04-2006 04:39 PM - edited 12-04-2006 04:39 PM
Hi Spider_1112006,
It sounds like you might have a short somewhere - if you use a completely different set of channels (r1, different combinations of the columns) do you still get a hang? If you use a floating voltage (battery) at r0 and read the columns with your dmm, does the voltage switch through correctly? Also, does the PXI system throw an error or give some sort of message? Does it blue screen or just hang? What happens if you do this in just a test panel? Just for info, what kind of current are you switching? I would expect different symptoms (hangs are never expected ) but its worth checking.
Hope this helps, please post back if these suggestions don't shed any light on a solution.
Andrew S.
Message Edited by stilly32 on 12-04-2006 04:51 PM
Message Edited by stilly32 on 12-04-2006 04:52 PM
