PXI-2530 Matrix Control Examples
I am searching for examples that show how to control the PXI-2530 as a 8x16 Matrix. I searched but was unable to locate code to help.
(3,110 Views)
There are a couple of shipping examples in LabVIEW that say they work with the 2530. Where did you search? For example, the niSwitch Making Connections on a Switch.vi. You would have to manually enter the channel names but you can select the topology from a combo box. The channel names are just cx and rx as you can read from the NI-Switch help.
(3,091 Views)
I second that!  I have created several different applications using the PXI-2530 in the 8X16 matrix topology. I built the row and column designators mathematically from for loop indices and pre-programmed them as array constants. The rows are identified by "r0" thru "r7" and the columns are identified by "c0" thru "c15".
Jeff
Jeffrey Zola
(3,081 Views)
