PXI 2548 Card issue with Switch executive
I am using PXI 2548 card to switch the RF using switch executive. But it is not working as expected. I am trying to test 4 UUTs at the same time and I am switching relay respective to the UUT. On test start switch has to be at nco à com0 and run some tests. Then switch to no0 à com0 and test rest of the RF for the UUT1, but sometimes it never switch to no0 à com0. Here is my configuration file and please let me know what I am doing wrong? Is it a card problem or is it my configuration problem? How do we know the switch status using switch executive?
(2,597 Views)
lv2010,
I've been in contact with Will, the application engineer you have been speaking with and will be working with him to help you with this issue.
Peter C.
(2,575 Views)
Please get the solution as soon as possible. Because our porduction is on hold.
Thanks in advance.
(2,571 Views)
