PXI 2569 reset counter
how is it possible to reset the switch counter of the PXI 2569 relaycard?
To read I can use the ViStatus niSwitch_GetRelayCount (ViSession vi, ViConstString relayName, ViInt32* relayCount);
Doesn't matter if CVI or LabVIEW. This must be possible somehow.
regards
MB
(3,052 Views)
Hello MB,
the relay switch counts are only available for reading through the NI-Switch and NI-DAQmx APIs. The is intended, as the use of this counter is to track relay usage, enabling maintenance personnel to decide when to replace the card's relays. To reset the switch counts after relay replacement, open the NI-Switch Soft Front Panel and chose File » Relay Maintenance (see screenshot):
18181i749305238B120303
Sebastian
(3,028 Views)
Is there a way to do this programmatically?
(2,853 Views)
