PXI-5102 Digitizer Trigger Problem
The attached VI was written in LabVIEW 8.0 and called through TestStand 3.5.  Occasionally, I get the following error: BFFA2003, "niScope Multi Fetch Cluster.vi, Max time exceeded before the operation completed.  Posssibly no trigger received."  Can anyone offer a sollution to this problem?  I'm using the PXI-5102 Digitizer in a PXI-1050 chassis.
Thanks in advance.:smileyhappy:
(2,743 Views)
Posts will be made on original forum
Rohan B
(2,712 Views)
