04-12-2017 12:19 PM - last edited on 05-04-2017 06:13 PM by karina.barles
I'm trying to perform a FM Deviation measurement of an AM Modulated signal.
CW= 118.5MHz, AM Modulated 70% @ 1KHz
Attached is code that I'm running and the FM Deviation measurement is not working
See RFSA FGV enum (Get Demod Data)
Solved! Go to Solution.
04-13-2017 03:50 PM
Hello Tronman,
Thank you for your post! I have several questions that may help us to understand why the FM Deviation measurement is not what you are expecting. I have listed these questions below:
I hope these questions help to narrow down what is going on and get your code running successfully!
Best,
Casey L.
Applications Engineering
04-17-2017 11:04 AM
The equipment utilized is PXI-5600 & PXI-5142, The incoming signal is VHF band 118MHz to 137MHz AM Modulated 70% @ 1KHz. I'm conducting RTCA/DO-186B section 2.3.11.c testing; the frequency deviation due to unwanted frequency modulation of the carrier shall not exceed +/- 3KHz. I'm not conducting an EVM measurement during this particular test.
