PXI 6133 - P0.4
Has anyone had problems using P0.4 digital input on a PXI-6133 card?
I've tried to use it on a couple of cards and cant get it to work, all other lines on the port work fine.
Any ideas?
I dont think it is anything I am doing. Is this a known problem?
(3,133 Views)
Does anyone have one of these cards?
(3,113 Views)
Accepted by topic author scottcolston
Hi Scott,
I assisted you in testing the PXI-6133 card and together we found that the cable connecting the card to the SCB-68 was a SH68-68-D1 cable, which is typically used with our digital products where pin 19 (P0.4 on the PXI-6133) is not connected. The correct cable is the SH68-68-EP for the PXI-6133.
The SH68-68-D1 and SH68-68-EP cables look identical, the only visible difference being the part numbers on their label.  184749-xx for the SH68-68-EP and 183432-xx for the SH68-68-D1.
Tony Gibbs
AE NIUK
(3,099 Views)
