PXI-6723 PFI Question
Is there any way the 10 PFIs on the PXI-6723 can be used as general-purpose DIO lines in LV 8.2?
(2,581 Views)
No. There's to my knowledge no possibility to use the triggerlines as input in you're LV application. Whether or not something is possible in a LV version depends on the driver that the device uses and whether or not the driver is supported in a LV version. All can be derived from documentation.
André (CLA, CLED)
(2,565 Views)
