PXI 7314 not seen in MAX
I also use PXI 7314 module. But module not seen in MAX.
The module seen in Device Manager but not seen in MAX.
In device manager it seen National Instrument Motion Controller - PXI-7314
(2,654 Views)
Please follow a single thread, if you start multiple threads then the other users having similar problem may not be able to get proper solution.
As already asked did you install the driver properly, you need to have the LabVIEW RT and device drivers installed to have the hardware availabke in MAX.
(2,637 Views)
