PXI-7953 FPGA Module for FlexRIO
Which Labview FPGA module version is support NI PXI 7953?
(2,103 Views)
Hi Ali,
check this NI website
(2,086 Views)
Hı GerdW,
I look this page, but  I can not see Labview FPGA modüle version. This page shows me Compilation Tools
Kind regards,
Ali
(2,056 Views)
Hi Ali,
you can select your hardware, then you select your LabVIEW version and then the website tells you which compiler you need to use…
When selecting LV2010 it tells you to use a more recent version of LabVIEW:
(2,042 Views)
Hı GerdW,
I understand you. I need Labview FPGA Modüle. I look at this page " https://www.ni.com/en/support/downloads/software-products/download.labview-fpga-module.html#346249 " but I dont see version compatible with PXI-7953
Kind regards
(2,032 Views)
Hi Ali,
as shown above your hardware is supported by LV2010SP1 or newer…
(2,029 Views)
