PXI-8106 RT
Hello !
I am using PXI-8106 RT with PXI-4461 in chassis PXI-1024,
when I used DAQ assistant , an error show up with the following message
The remote target is missing the required components.
what does it mean ?
do I need to set PXI_trigX in the chassis?
any suggestions,
Message 1 of 8
(3,722 Views)
Hello bachir_elec,
I would suggest you to do a repair in your DAQmx drivers. You can do that by going in Control Panel-->Programs and Features --> Software National Instruments and repair NI-DAQmx Drivers. An even better idea would be to update your DAQmx drivers into the latest version supported for your system software.
You can see the compatibility between LabVIEW versions and DAQmx drivers version in the following link.
Can you try a repair or a new DAQmx driver installation and see if the problem persists?
Antonios
Message 2 of 8
(3,709 Views)
Thank you A. V.
I re-install it but without seccuss.
When I tried VISA test panal in MAX I got the following error code
VI_ERROR_NPERMISSION (permission denied)
even though under NI-VISA tools -> security, I have '*' for all permission !!!!.
so what could be the problem ?
Message 3 of 8
(3,703 Views)
Hello bachir_elec,
 I have located a knowledge base article that explains the reason you receive this specific error. Can you please take a look and write here if your problem  was solved by following the instructions inside?
http://digital.ni.com/public.nsf/allkb/293080923B466C9A86257141005775FD
Thanx!
Antonios
Message 4 of 8
(3,694 Views)
Yes I saw this link and I have already check the permission
But still I got the same message :(.
Message 5 of 8
(3,691 Views)
Hello bachir_elec,
this is strange. Have you installed correctly the appropriate software in your target?
Antonios
Message 6 of 8
(3,677 Views)
the versions are the same in remote and the host as you can see in image.
Message 7 of 8
(3,674 Views)
The problem was the compatibility between OS on the host(windows 7) and labview version 8.6.
Message 8 of 8
(3,662 Views)
