PXI-8183 Windows XP Ethernet driver needed
I need the Ethernet driver or at least what kind of chipset the Ethernet driver is.  I acquired a PXI-8183 with DOS on it and I am updating it to Windows XP to run application builder executables on it.   Can you send to the drivers, driver disk, or tell me which currently available drivers will work?  Thanks for your help.
Don Whitney
321-724-9992
(2,461 Views)
Hello DonW,
I believe you may be working with one of my colleagues regarding this request however the drivers linked below have proven to be successful for other customers with the same controller.
Network driver:
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=18717&lang=eng
Chipset driver (if you wanted that too):
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=4665&lang=eng
Wes W
Application Engineering
www.ni.com/support
(2,429 Views)
