PXI 8252 not seen in MAX
I have PXI 8252 1394 Host Adapter in my PXI 1000B chassis. PXI is controlled using MXI-3 fiber optical communication.
NI PXI 8252 is not seen in MAX.
I want to program the 8252 using LabVIEW but it is not seen in MAX.
Thanking You
Kiran Patel
(2,775 Views)
Are you able to  see the PXI chassis in MAX?
(2,763 Views)
First you need to add chassis and then modules to it. If you are not able to locate chassis then drivers are not installed for PXI
(2,756 Views)
