PXI-8431/8 card Simulation in Labview
Hi All,
I'm new to Labview Development Environment. I have a query which I would like to clarify with you guys. I need to simulate PXI-8431/8 RS 422 Serial card and use it as resource in Labview for coding purpose. I tried adding DAQ-MX simulation instance in MAX and tried searching for this card but unfortunately couldn't find it in the list. Can anyone help me out in suggesting a method to simulate 8431 card in NI MAX? Thanks in advance
(2,868 Views)
Hi Mohan,
RS422 is not related to DAQmx, so you cannot simulate this card by creating a simulated DAQmx device…
(2,846 Views)
Hi GerdW,
Thank you so much for your prompt reply. Now, I understand that we can't simulate 8431 card using DAQ-Mx simulation method. So, Is there any other means to simulate the Serial card?
Madan Mohan
(2,834 Views)
Accepted by topic author MadanMohan
Hi Madan,
AFAIK there is no other way in MAX. VISA-related hardware cannot be simulated in MAX.
You could create a HAL (hardware abstraction layer) in your software and write your own simulation for those COM ports…
(2,821 Views)
