PXI_Clk10 for Timed Loop DAQmx Timing Source
I'm trying to set a timed loop that uses a DAQmx counter channel as the timing source. I'm able to set up the timed loop and everything works as expected but the problem is after the timed loop starts I'm attempting to start a analog input task and it errors out for reference clock in use. I'm aware of why this problem is occurring (which is explained here: Why Do I Get a Resource Error -89137 When Using a Reference Clock with NI-DAQmx Devices?) but how can I specify which reference clock the timing source uses? The timing source property node doesn't seem to have anything to specify that. Any ideas?
(3,323 Views)
Accepted by topic author jed255
I was able to find a solution, it's not really ideal but seems to work just fine.Timed_Loop_Solution.png
(3,290 Views)
