PXI RT Controller with DAQ
I am designing a new real-time control system. My application requires 1 analog input, 2 encoder inputs and 1 analog output output per axis. I need 20 axis PID controller that can handle such inputs/outputs with 300 Hz PID update rate. PID algorithm will read 1 analog input or 2 encoders to compute and output servo command (1 analog command) per axis. The axes are independently controlled.
After reading your materials in your web-site, it looks like that the Embedded Real-Time Controller PXI-8145 RT with LabVIEW RT software can handle my applicaion with A/D, D/A and counter board. Please consider the following configuration of mine and get me your opinion/quotation.
1. 1x PXI-8145 RT (PXI Embedded Real-Time Controller)
2. 1x PXI-6254 (M series multu-function DAQ with 32 channel A/D)
3. 1x PXI-6723 (32 channel D/A Board)
4. 5x PXI-6602 (32-bit, 8 channel Timer/counter board)
You can recommend other low-cost 16-bit Timer/counter board because I need just 16 bit counter.
With the above configuration, I would like to know if PXI-8145 RT can handle my application. 300 Hz PID update rate is very slow compared to modern industial application, so I assume it can handle my application.
Someone say I will need another Motion controller like PXI-7358 to handle my application. I wonder I need the motion controller in my application. I don't know what the role of the motion controller is compared to the PXI-8145 RT.
(2,933 Views)
This looks like it would probably work fine. My one suggestion is if you can fit it in your budge consider getting a different controller like the 8186 or 8187. Though much more expensive, there is a lot more horespower there in case you want to ever change your application. Also, depending on your appliations algorithms with this number of channels it might be difficult to get the 300Hz rates. Just a thought.
(2,913 Views)
(2,875 Views)
