PXI Trigger on 5122 Fails
I am triggering a 5122 from an FPGA card using a PXI trigger line.  The 5122 appears to never trigger (no data ever returned).  I replaced the PXI trigger with an external trigger from the FPGA and it works fine.  I tried several different lines and none work.  Am I missing something?
TIA,
Bill F
(2,702 Views)
Bill,
Do you have any other cards in your PXI chassis that you could use to try to trigger the 5122?  Or a different card to try to trigger with the FPGA card.  Those would be two things to try.  Also, see if switching slots in the chassis makes any difference.
-Christina
(2,682 Views)
