PXI configuration
        we need a PXI system. we need to test power amplifiers. the input frequency range is 80MHz- 500MHz and Input  signal level is from -10 to +10 dB(CW). The parameters we are measuring at the output of the amplifier are Harmonic Radiation, Spurious Radiation, and power.  The output power of the amplifier will be upto 50W.
please suggest a PXI system for us.
Regards
RobinHood
(2,722 Views)
Robinhood,
Please take the time to check out our website at http://ohm.ni.com/advisors/pxi. This page will allow you to step by step configure your PXI system in an intuitive manner.
If you have any questions you can call into our Technical Sales Reps at (866) 337-8763; they have the ability to answer some technical questions and have the ability to direct you to an applications engineer with even more product knowledge to configure your system if necessary.
Joel Khan
Applications Engineering
BSEE Rice University
(2,704 Views)
