PXI local bus
Does any of the NI cards (or other vendors) use the local bus on the PXI card cage?
Message 1 of 9
(3,646 Views)
Currently the only boards that use the local bus are our Multifunction DAQ E Series Boards.
They only use the local bus when installed in the right most slot of a PXI Combo Chassis (PXI-1010 or PXI-1011, the chassis that come with a SCXI chassis attahced to it). They use the local bus to control the SCXI portion through the backplane.
The driver of the boards (NI-DAQ) reads the PXISYS.INI file that corresponds to the combination of chassis and controllers, and finds out if the boards can use the local bus or not.
Find out information on how to configure this systems at the following link:
KB 1NFF457T : Configuring a PXI-1010 or PXI-1011 Chassis
Find mor
e information about PXI Initialization Files (PXISYS.INI files) at:
KB 1EGB71UI : What Are PXISYS.INI and CHASSIS.INI?
PXISYS.INI files for every combination of NI PXI chassis and controllers
Hope this helps,
Claudia Lorente
PXI/VXI Specialty Products Group
http://www.ni.com/ask
Message 2 of 9
(3,646 Views)
Hi Claudia,
I would to humbly request that you register as an enthusiast. If you do so, others can subscribe to your answers.
Ben
Message 3 of 9
(3,646 Views)
Ben,
I just signed up to become an enthusiast... So far I am waiting to be approved....
Wish me luck,
Claudia
Message 4 of 9
(3,646 Views)
Thank you.
Please update here when you get the word.
Ben
Message 5 of 9
(3,646 Views)
I am an enthusiast, Ben. Thanks and write you later 🙂
Message 6 of 9
(3,646 Views)
Cool!
Now your answers will be mailed to me each morning along with the other brains I subscribe to.
Ben
Message 7 of 9
(3,646 Views)
I need to add a correction to the answer I posted above. Not only E series boards use the local bus. There are other boards that use it, although for the same purpose, this is, to control the SCXI chassis.
Some boards are capable of sending the controlling signals to the SCXI chassis AND receiving/sending signals from/to the SCXI modules through the local bus. Other boards are only capable of sending the control signals to the SCXI chassis, so it is necessary to read/send signals from/to the SCXI modules by external cabling.
The following document summarizes how NI PXI boards use the PXI Backplane timing and synchronization features:
KnowledgeBase 2W1AOUW
D : How do National Instruments PXI Boards map to the PXI Backplane?
Claudia Lorente
Modular Instrumentation Specialty Products Group
Applications Engineering
Message 8 of 9
(3,646 Views)
What I was looking to do from my original post is find a way where I could use the local bus to control custom PXI cards. I am just looking for a way, either through a daq card or directly from a controller to send and received data on these lines.
Message 9 of 9
(3,646 Views)
