I am using a PXIe-4081 DMM for 2-wire resistance measurements in an automated test setup. I am running the application modified from a LabVIEW 2015 example.
The issue is that the measurement runs perfectly fine for several hours (e.g., 5 hours) before it stops randomly with an error.
Since this error occurs intermittently after long periods of stable operation, I suspect it might be related to environmental factors, hardware stability, or timing.
Could you please advise on the most likely causes and solutions?
