06-20-2012 12:20 PM
I was wondering if there is anyway I could set the PXIe 4330 Exitation Voltage to Zero in Labview as a safety precaution when wiring the card?
I have tried to do so with the DAQmx Reset Device.vi but it has no effect.
As well, I tried DAQmx Create Channel (AI bridge).vi with the Voltage exitation value set to zero but that returns an error.
Any ideas?
Thanks in advance
06-21-2012 04:16 PM - edited 06-21-2012 04:16 PM
G'ory88,
I don't think you can set it to zero, but you should be able to set the excitation voltage as low as 0.625 V in software. If you are extremely concerned, you can turn off the chassis, do the wiring, and then turn it back on (if you are using a PC through MXI make sure you power off your PC first).
Hope this helps.
Best,
