PXIe 4499 TEDs problem
Hi
I have 2 DSA cards,
4461 and 4499. I can easily configure the TEDs on 4461 when I click on Scan for HW TEDs but when I do the same using 4499 I can't detect the TEDs and I get this error message
Error -200709 occurred at Configure TEDS
Possible Reason(s):
No TEDS sensor was detected on the specified physical channel.
Ensure that your sensor is properly connected. If the sensor is connected to a TEDS interface device with addresses, make sure the configured address matches the address set on the interface device.
Could you please let me know how should I configure TEDs for  4499? The same TEDs microphone is connected to both of them
Message 1 of 1
(2,988 Views)
