PXIe 4844 Lab view does not show the measurement from OSI Explorer
I am using NI OSI explorer to detect the peaks for each FBG sensor.
1- 4 sensors are connected to NI PXIe.
2- I connect PXIe to a laptop which instelled OSI explorer and lapview software.
3- The sensors' measurement were not detected except for the senosr that has Minimum Width at level more than 0.1.
4- I changened Minimum Width at level from 0.1 to 0.05 for the other three senors to detect the peaks. afterword, I saved the NI OSI explorer and closed it.
5- I started Labview and relate each sensor for it channel.
6- The only sensor that gives measurement was the one that has Minimum Width at level more than 0.1.
I would like to know how to get the measurement for the other sensors.
Finally, I can not save the measurements of the four senors, I only can svae for three sensors only in Excel format.
I attachet a pdf with screenshots of the problems
Message 1 of 1
(3,031 Views)
