PXIe-5413 Synchronization and delay programming of both channels
Thank you for your reply!
I will try the start trigger to synchronize the two channel signals.
Regarding the problem of signal B_delay, I am looking for a method for signal delay, and I have thought of several ways:
1. Sample clock relative delay; 2. Marker events (but the pulse width may be less than 500 microseconds)
3. Script trigger; 4. Frequency list mode; 5. Arbitrary sequence mode
What I want to achieve is that the Signal B pulse width is 500μs, and the delay of each cycle of the wave is 0:100:1000ns for a cycle,
Which way do you think would be more suitable?
Message 11 of 13
(453 Views)
My question was whether you would know all the delays for all cycles before starting the waveform generation or are you expecting to change it on-the-fly?
Santhosh
Soliton Technologies
Message 12 of 13
(449 Views)
Yes, the number of cycles and the specific delay time of each cycle are the parameters I want to set, which are determined before generating the waveform.  Which method do you think is more suitable?
Message 13 of 13
(443 Views)
