PXIe-5433, using two channels independently.
Is it possible to choose different generation modes for each channel when using the two channel generator card PXIe-5433? I'd like to use an arbitrary sequence on one channel, and a frequency list on the other channel.
If it's not possible, I'd like to create one arbitrary sequence for each channel that are of different lengths. Then, I'd like to use a continuous trigger for both channels so that it generates both sequences indefinitely. The only way I could make it work, as of now, is if the two waveform sequences have the same length and I interleave them (see vi attached).
Any hints on this would be greatly appreciated.
Jacques
Message 1 of 1
(989 Views)
