PXIe-5840 FPGA
Hi!
Recently I want to use the on-board FPGA of the PXIe-5840. I have downloaded and installed the Labview FPGA module and even the Labview Runtime, but when I try to add the target FPGA device in the project(Right click "my computer-add"), there is nothing showing up. All the hardwares are connected properly as they can be found in the MAX. I am using Labview 2017.
Is there something wrong when I did this? Thank you very much.
Edward
(2,744 Views)
See item 4 on http://www.ni.com/white-paper/14646/en/
You may have to request this access from NI.
Certified LabVIEW Architect, Certified Professional Instructor
ALE Consultants
Introduction to LabVIEW FPGA for RF, Radar, and Electronic Warfare Applications
(2,725 Views)
Hi Terry
I think you are right.
Thanks.
(2,710 Views)
