PXIe-6535 Digital Output only P0_L0
I am turning to help here as I have exhausted every search and example I can find...
I have a chassis with 4 PXIe-6535 Digital IO cards.  I need to output a pulse of 100us @ 300Hz (3% Duty) on 24 of the 32 channels.
These pulses need to be staggered delayed across the 4 6535's, however this is getting way far ahead from where I am currently stuck.
I have created several VI's for configuring and outputting the pulse, and I can ALWAYS get a desired pulse output on port0 line0, of each card.
I cannot get the function to produce and output on any of the other channels in the card, no matter what I do.  I change the target line and run, and the Active LED on the slot lights up, but I cannot see any pulse when I measure the cable with a scope unless I have selected Line0.
In MAX, I can create a DigitalOut task for any of the channels, set to continuous samples, and always get an output - so I know the hardware is functioning.
I have uploaded an image of one of the VI's that I created based on a search and example for this problem, and again this works great if I am choosing Line0.
Hopefully someone can point out the silly and simple error that prevents this from working on all the lines of the card!  Thanks in advance
(3,189 Views)
Hi mblock,
Thanks for reaching out. It looks like you are trying to write a binary array to a DAQmx integer write function. Essentially, you are writing the number 1 in binary represented by 5 lines or bits for 3 data points. if you were to write the number 3, instead of one, you will see the same graph, but you'll see line 0 and line 1 go high for 3 data points, then low for the remaining of the array. For 4, you will see line 2 go high and line 0 and 1 go low. This is assuming you change your Control to be PXI1Slot2/port0/line0:5, and your write function to multiple channels.
What you want to do, I think is represent each line as a data point in your array. As in if you want to write line 1 high and the rest low, you would feed the array 01000 right? You will have to change your DAQmx write function accordingly, instead of a 1D Unassigned 8bit integer. (1D U8).
Does that make sense why you are seeing the behavior you are experiencing?
Keddy C.
Staff Software Engineer
(3,145 Views)
Thank you keddy for taking the time to respond and answer my question.  Changing the value to 3 worked exactly like you predicted!  I just sent 255 to apply the high to all 8 lines in the port and it looks great.
Only issue I have now is I cannot get it to work past Port0.  When I try and send the same routine to the 8 lines in Port1 there is no output.  Do I need to send another digital waveform for each 8line port (0-3) in the card?  I need to have 24 of the 32 channels outputting the pattern...
Matt
(3,138 Views)
Matt,
No problem, it's what I'm here for.
I'm not sure right away! Let me ask you a couple questions: If you select port 1 or another port in your channel reference name, does anything output? If you select multiple ports in NI MAX does it output on all ports? What happens when you send a separate digital waveform to another port?
Keddy C.
(3,122 Views)
Hi Keddy,
So I went back and reread your original reply and found that it contained all the advice I needed.  I changed around the DAQmx write method and am now able to output pulses on each channel, across all 4 slots.
Thanks again!  Next time I will be slower in my reading comprehension 🙂
(3,107 Views)
mblock,
Glad I could help. We all could slow down and read a little more. Best of luck to you.
Keddy C.
(3,102 Views)
