PXIe-7846 SPI on FPGA
Please explain how the NI FPGA SPI example works. I have a lot of questions on it .
(4,045 Views)
I found this thread might be the thing that you are looking for?
https://forums.ni.com/t5/LabVIEW-Robotics-Documents/Implementing-SPI-Communication-Protocol-in-LabVI...
or
https://forums.ni.com/t5/Example-Program-Drafts/I2C-and-SPI-communication-on-FPGA/ta-p/3823804
Else, in LabVIEW FPGA, you can use the Digital IN/OUT (IO nodes) and output/input high/low like other digital logic if you want to have customization on your SPI protocol.
(4,015 Views)
HI,
THANKS for your generosity,
l have downloaded the example <NI SPI IP >form VI package manager , and my problem is l can not run this Host vi in simulation mode. And l want to how to konw how to alter this project and use it in my PXIe(7846R) to achieve spi comunication.what's more, In terms of hardware configuration, l want to kown the committed step in detail.
(3,994 Views)
Sorry I am not familiar with the package. Probably you want to contact NI customer support.
(3,987 Views)
