PXIe-7902
Hi there,
I am currently working with the NI PXIe-7902 High Speed FPGA module, and I want to output data to one of the TX/RX terminals using the MiniSAS-SMA breakout cable (SA-44SMA-16X).
I’m a bit unclear on how to connect to the TX/RX terminals, aka drive the serial lanes,  via the ports on the PXIe-7902 using the MiniSAS-SMA breakout cable.
Has anyone set up a similar configuration?
Thank you!
Message 1 of 1
(749 Views)
