PXIe-8301 + LabVIEW and Test Stand
Hi
I am posting this question about PXI here because the PXI is not available.
Has anyone used PXIe-8301 Thunderbolt 3 Remote control module with PXI chassis with LabVIEW + Test stand ?
I'm exploring this solution, does it has any combability issues with other old PXI boards ?
(567 Views)
In short, PXIe-8301 on its own does not cause any compatibility issue. Please ensure that you have a compatible combination of drivers, hardware, and LV to use it.
To use PXIe-8301, you need a PXIe chassis, and check if your existing cards are compatible with that chassis. Another thing is that ensure that your computer has a native Thunderbolt 3 and not using a addon card, despite this, there is a small chance that your computer's thunderbolt 3 is not upto the standards that is required for PXIe-8301 to work properly, no, there is not foolproof way to check your computer to see if it is compatible without testing the actual setup.
Santhosh
Soliton Technologies
(552 Views)
