PXIe1073 with two NI-4461 cards
The 4461 specifications indicate an internal timebase accuracy of 20 ppm. So, if you start two 4461 devices at the same time, and you set the sample rates to the same value (those rates will get resolved to exactly the same values), the relative timebase error between two devices could be as much as 2*20 ppm. Given OP is seeing ~1 ppm, it is fair to say that these clocks are accurate (within 20 ppm) and fairly well matched (within 1 ppm). But, they are not clock synchronized. 1 ppm is not big, but at 200 kS/s, 1 ppm translates to 720 samples per hour. However, channel expansion will clock synchronize and start synchronize all the channels in the task. To mcduff's question: channel expansion takes care of all routing of triggers and clocks. @Tamirsh, channel expansion results in zero drift between devices even if there is a small error in absolute clock rate per Yameada's comment.
Doug
Enthusiast for LabVIEW, DAQmx, and Sound and Vibration
Message 11 of 18
(355 Views)
Doug,
I tried to search LabVIEW Help (the 'modern' one .. LV 25Q1 😕 ) for 'channel expansion' but get no meaningfull result 😞
Do you have some links for concept, supported devices, .... ?
How does it relate to NI-Sync/T-Clk   and how does it work together with NI-Scope/FGEN ... ??
Edit: I found some knowledge articels in the web search ..   But shouldn't there be a hit in the LabVIEW help?
Greetings from Germany
Henrik
LV since v3.1
Message 12 of 18
(324 Views)
@Henrik_Volkers wrote:
Doug,
Channel expansion is currently supported by the following drivers,
NI DC Power
NI Scope
NI Digital
NI DAQmx
These drivers under the hood uses TCLK sync and other concepts to synchronize the instruments involved in the channel expansion or multi-instrument sessions.
Santhosh
Soliton Technologies
Message 13 of 18
(317 Views)
Doug,
NI DC Power
NI Scope
NI Digital
NI DAQmx
I don't think Channel Expansion is supported by NI Scope; I had to use TCLK and sharing the reference clock to sync modules just recently. Not sure about the other drivers, but I thought DAQmx was the only API that supported it.
Message 14 of 18
(304 Views)
I have only used channel expansion in the context of DAQmx devices. DSA family of devices were the first DAQmx devices to support channel expansion.
Easily Synchronize and Trigger NI-DAQmx with Channel Expansion
@tamirsh, how goes your effort?
Doug
Message 15 of 18
(292 Views)
@mcduff wrote:
Doug,
NI DC Power
NI Scope
NI Digital
NI DAQmx
NI Scope started supporting from 19.1, Using Multi-Device Sessions With NI-SCOPE - NI Community
Pass comma separated list of fully qualified channels to Initialize, like you would do in DAQmx.
Initialize - NI
Santhosh
Message 16 of 18
(288 Views)
The interesting part would be to sync different devices ...like it's mentioned for DAQmx
from santo s link:
Hardware and Software Requirements
Hardware: Multiple PXI oscilloscopes of the same model in the same PXI chassis
Software: NI-SCOPE 19.1 or later
Henrik
LV since v3.1
Message 17 of 18
(257 Views)
 Channel expansion works for different devices in the same chassis. I have synchronized many different combinations of DSA devices: 4499, 4464, 4461, 4468,  etc.
Channel expansion is not supported across different drivers - this requires explicit synchronization code and routing/connections.
Doug
Message 18 of 18
(251 Views)
