PXie 7976 Clock generation
I am trying to use my flexRio to generate essentially an 80MHz clock. I created multiple versions to test and try to find the best clock.
I tried creating a clip as well as just a vi. For some reason, both generate an 80 MHz clock +/- .4MHz, but from looking at the datasheet, it should be able to generate a much better 80MHz signal.
My vhdl code is essentially this where count_M80 is a counter from 0 to M80, M80 is 0 to 1 (since my clock is 160MHz and with 50% duty cycle, 160/80*.5 = 1), and register_m80 is just a std logic and connected to my output.
	begin
		if rising_edge(clock) then
			if count_M80 = M80-1 then
				register_M80 <= not register_M80;
				count_M80 <= 0;
			else
				count_M80 <= count_M80+1;
			end if;
		end if;
	end process tutorial;
 I tried the below to generate an 80MHz clock too by having the below in a 160MHz timed loop.
Shouldn't my clock output be a lot more stable? I have the clock connected to PXIe_DstarC and have a ni-sync vi to measure it.
Message 1 of 9
(2,228 Views)
It looks like your are using a NAND with a True to toggle the boolean.
Wouldn't it make more sense to just use a NOT?
Message 2 of 9
(2,195 Views)
It makes no difference. I have one version where I'm using a NOT gate and its just as volatile/unstable. I just didn't want to post essentially the same picture but with a different gate. My apologies.
Message 3 of 9
(2,176 Views)
Will this clock be interfaced with an I/O pin?
Asking because I rarely see such an implementation in LabVIEW FPGA since we typically derive clocks from the base clock(s).
Certified LabVIEW Architect, Certified Professional Instructor
ALE Consultants
Introduction to LabVIEW FPGA for RF, Radar, and Electronic Warfare Applications
Message 4 of 9
(2,162 Views)
Update, Ive even tried all these to get essentially the same result
https://forums.ni.com/t5/Example-Code/Export-a-Clock-Signal-on-FPGA-Device/ta-p/3530075?profile.lang...
Message 5 of 9
(2,157 Views)
Ideally this would be sent to the DStarC line and then outputted through a timing card.
Message 6 of 9
(2,155 Views)
That's an older (2010) document; I'd look for something more recent.
It is for DAQ cards but this may help: https://www.ni.com/en-us/support/documentation/supplemental/10/synchronization-explained.html
ALE Consultants
Message 7 of 9
(2,151 Views)
So I believe I am doing what they recommend (Using the DStarC lines since im going from FPGA to timing card which is considered the best). It says I should expect about <500 ps of skew, but when I'm measuring it, im off by like 400 KHz which doesnt seem to make sense, unless its potentially from the ni-sync measure frequency accuracy? I've used the measure frequency vi prior and it was pretty accurate prior. I don't imagine the DStarC line to be that noisy or cause that much jitter?
Message 8 of 9
(2,147 Views)
Not sure what else to recommend.  May be good to reach out directly to NI support.
ALE Consultants
Message 9 of 9
(2,142 Views)
