Package manager compatibility
Hi, i download LV 2020 and then 2020 SP1 on Win 7, but installation window told me, that can't find package manager. I try to download manually, but each version (from 17-22) i tried, says that is for Win 10. How to fix this?
(2,663 Views)
Uninstall everything! As soon as you install anything with version 20.7 or newer from NI, the Meta Deployment Framework (MDF) is updated to 20.7 or newer and that does not support installation into Windows 7 and/or any 32-bit Windows platform.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YOE0CAO
Rolf Kalbermatter  My Blog
(2,638 Views)
When i checked control panel i don't find anything, but when i try to install NIPM 20.6, the window tell me that it is already installed. When i try to install LV i have same error. What to do?
(2,624 Views)
Fully uninstall all NI software. And yes that may be easier done by wiping the HD and reinstalling Windows and all software than trying to go through each uninstaller. Some things will not simply go away by uninstalling, since Windows may consider it in use by some of its own components (File Explorer, etc.)
(2,607 Views)
I can't find any NI software on my system. I can't wip the HD, because i have some projects on the run.
How to find NI related software on my system?
(2,603 Views)
