Packed Library Build Error
I have two Classes say Class 1, Class 2 in a project. Class 1 has array of Class 2 objects and use accessors from Class 2. Now I have replaced the Object in Class 1 with DVRs and accessors with property nodes. When I try to rebuild the packed library again, the below error occurred. Suggest me a solution for this issue.
Message 1 of 1
(1,215 Views)
