Packed Project Libraries
Hi all,
Currently, I am exploring on packed project library and how it can be used to distribute a code. But I have some doubts regarding this. I would like to know whether the PPL(i.e.).lvlibp file will include all the dependencies in vi.lib and user.lib or not. If not then will it use it directly from the user.lib/vi.lib directory in LabVIEW folder.  Anyone who is aware of the topic can please help.
Thanks for the help in advance.:)
Ramya
(3,775 Views)
Accepted by topic author Ramya12
The PPL will pull in all of the required dependencies it needs during the build just like an executable - as long as you have the appropriate version of the LV runtime-engine etc. installed then the code should run fine from the PPL.
(blog)
(3,755 Views)
Thankyou
(3,741 Views)
