Packed library and SQL Toolkit
Hi
I have labview development studio and I have made some test software that runs a test and posts the results to a database.
I have built the functions of the test in to a packed library
Another company will be using the packed library to test some pcb's for us. The problem is that they do not have the database module in their labview and so the database section of the code does not work.
Is there a run time program for the SQL toolkit I can give them?
(3,142 Views)
Accepted by topic author shavecp
No, but you can replace them with these drivers and not have to worry about toolkits. Be sure to read the discussion too - it will give you other reasons why you are better off without the DCT. The download link for a current version of LV is on the last page of the discussion.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,115 Views)
I agree with Mike though I have typically used LabSQL.
If insist on using the NI toolkit, the vendor will require a license for it, just like they would require a LabVIEW license. If that is a problem, don't provide the source code. Create an exe.
(3,111 Views)
